Hi, I am finally just about ready to bring my 31 plymouth coupe to its first test & tune ever at the drag strip. This is a new build, intended for Drag Week 2018 this September, and it is my first 4 link/coil over car ever.
Here are the specs as best as I can figure:
weight about 2700 with driver
flywheel horse around 675
t-56 magnum manual trans
mcleod soft lock clutch
4 link rear with afco double adjustable coil overs and a sway bar
straight axle in front with hair pins and afco double adjustable coil overs
30x13.5-15 MT ET streets
9" with 4.20 gears
How should I dial in the corner weights? WIth my small tire leaf spring stuff, I always made the right rear and left front heavy, and the left rear and right front light. I have heard that you don't do that with 4 link, but I'm not sure. Can anyone please point me in the right direction on this? THanks,
Joel
Ok, there is no like button but that thing is bad assed cool. Hemi, stick and Drag Week. Doesn't get any better than that.
Nice build.
