hello
i bought a ford 9" rear with a Detroit locker 4.56 gears, i can turn the driveshaft yoke 1/2-5/8 of a turn before the wheels turn is this, ok????
i was told that the rear will click when i turn the play in the yoke is fine, i just have to make sure to keep the tire air pressure the same in both tires!!!!
thanks
