Originally Posted By AndyF
I'm interested in what the little dip in the driveshaft speed is from. If the tires are spinning it seems like driveshaft speed would go up but about 1/2 second after you launch the driveshaft speed have a dip in it.
What are the other lines on the display? There is one that is steady across the top and one that goes up at launch and then goes down the rest of the time.
I think the dip shows the tires were spinning a little & then hooked. Track was not the best & it was hot & sunny.
The line at the top is battery voltage. The one that goes up at launch & then down is G-meter.
