Originally Posted By HR3128
Originally Posted By AndyF
Looks to me like the car doesn't start to move until the 1 second mark. Is that correct? So the first second of this data log is you sitting on the line with the engine at 5000 rpm? And then at the one second mark you release the brake and the engine speed goes up and the driveshaft speed starts to go up? If that is case then I guess I don't see an issue.
That's it exactly. First second is the car staged with rev limit at 4800, brake releases & engine RPM goes to convertor stall of 6000 RPM, driveshaft RPM goes up. It ran good, 6.31, 6.34 & 6.35 1/8 mile times, all at 107.xx MPH.
I just expected to see engine RPM climb after the brake release rather than sit at stall speed for a second.
If you release the brake and still sit there you
have a conv problem if there is no delay in it
wave
