Found some misleading or confusing info. Alcohol and aluminum are not a good mix. Most modern electric fuel pumps are aluminum bodies and also the fuel filter canisters. Then there's the aluminum fuel cell and aluminum fuel lines. Ran alcohol in the moon tank of the altered with no issues that I remember. Was that the other benefit of the added lube?
