Thanks for the update.I'm following the exact same path. I'm waiting for the block to leave Ritters. Then it's going to QMP. I'm using a Molnar crank though.
Did QMP drill drain holes in the cam tunnel ?
No I didn't ask them to do that.
My Uncle was kind enough to help with that, we have to decide where and how big (hole size).
White Dart has been kind enough to share what he did with his block so I'm following the leader so to speak.
I'm going to do some other things to the block to make sure we have good oil return.
