i use the rubber ones but i have some M/T's covers on mine and you can crank them down very tight without worrying about warping the V/C's.
Try that with stock stamped steel valve covers and you'll get the results I described.
very true.
I run the MTs also wiit hthe rubber gasket. i run the rubber cause i have a solid cam and the rubber is better for removing VCs for lash adjustment. the corks gets hard and breaks after a short while.
