Andy - you should measure the voltage drop on the ground circuit. Measure from the negative battery post to the starter housing. I personally would use my Fluke 87 and use the min/max memory function at the fast sampling rate, but just watching it is fine. Between your ground cable and the body ground, the drop should be minimal. I would expect the drop to definitely be under 1 volt. Unfortunately I don't remember what mine came in at.
67 Coronet 500 9.610 @ 139.20 mph
67 Coronet 500 (street car) 14.82 @ 94 mph
69 GTX (clone) - build in progress......
