Now that I have a data logger (Sniper EFI system) I can see stuff that I haven't seen before. For example, I can see the system voltage while cranking. When the engine is hot the start slows down a little bit so I looked at the data logger and the voltage dips down to about 9 volts before the engine fires. That seems like it might be a tad low since the ignition system might get a little weak at that point.
Anyone else with a data logger know what their voltage is during a hot start? I'm not sure if I have a problem or not. If I do have a problem I'm not sure if it is starter heat soak or perhaps a voltage drop in the wiring.
