Originally Posted By mgoblue9798
If still pretty fresh, a rag with lacquer thinner should work. Be very careful not to spill any on or touch the rag on the fresh paint.
Lacquer thinner has worked for me before. As mentioned be careful. Keep the can of thinner far away and put a small amount - finger size - on a fresh rag to remove the overspray. That way you will not damage the paint.
A razor blade used carefully is good also... especially on edges where you don't want lacquer thinner to hurt rubber or paint.
