Weight in the form of a solid bar across your halo behaves very differently than weight under the floor.
Weight behind the axle center is cantilevered: it adds weight to the whole chassis, but subtracts weight from the front wheels. Weight directly above the axle center becomes cantilever when the front end rises; the higher it is the faster is affects distribution.
Boffin Emeritus
