I would add tabs and mounts for ballast in different locations in the car. Both ends and in the center. Use lead filled bars or pucks to get the weight where you want and need it. Moving 10 pounds can make a big difference as to whether it's dragging the bumper or blowing the tires off, especially with radials. Make the car light, use the ballast to get the extra weight where it's most helpful.
If the results don't match the theory, change the theory.
