Snoopy,
Thanks for the diagram. That oval hole at the very bottom, is that the hole for cudas for the filler tuber? Also, can you point out which ones are 3/4" as the 1" and 3/4" circles seem to be a bit close in size when I printed the diagram out.
Thanks again for your help.
Brian
