The other issue is that when you lower your truck, the rear shock mounting angle increases to a point where it can render the shock useless (depending how much you lower the truck). The top or bottom shock mount (or both) should be loved to reduce the shock angle. Anything beyond 30 degrees from vertical is too much.
- EM
