First of all, turn the damned boost up! I can fart and make 6 lbs. of boost! Turn it up to at least 10 lbs. Don't worry, your motor can take it! Not sure about the driver, tho.....
Secondly, I doubt that you are at the limits of your exhaust system. I ran a 3-1/2" exhaust system with the 3-1/2" Hooker AeroChambers, and my best time was a problematic pass of 9.16. I'd suggest uncorking it and see what the difference is.
I turned it up to 10 lbs with improvement.It sepatated one of the slip joints.Will uncork it and see what happens At South Mountain Raceway in July!
HEMI-ITIS has no cure. My condition is fully BLOWN!!
