Originally Posted By jeff500
Won't it be running to much total timing and ping. This is a bone stock 318
No, the $25 plate will allow you to reduce the slots so you can have 35 total. What springs are in there & we can work with them. I think you will be fine with 20 & if it cranks slowly when hot then go back to 15. Initial then total to 35 then work with springs (more on that later) then plug in/adj the can
