Depending on how much "stuff" you load in the camper, the average added to dry weight is usually considered to be about a 1,000 lbs. give or take. Granted, a TT does not tow as well as a 5er simply because all the tongue weight is at the rear of the truck. Add a weight-distributing hitch and maybe a sway control and you can come close. up
One other thing you may or may not need is either air bags or overload springs depending on tongue weight.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
