How did you phase the distributor? I like to drill a 3/8" hole in line with #1 in an old distributor cap and put a timing light on it to check rotor/plug wire alignment. Do you have a 4/7 swap cam and forgot about it when you reran the plug wires? Did you verify TDC timing marks before you started all of this?
[image][/image]
