does the dome light come on when you twist the knob on the light switch and the doors closed?
if it does then the dash lights should come on at the same time.
if they don't then you know it is isolated to the dash light harness.
if your gauges work then it isn't ground.
then I would start with power to the light harness, I might even back feed through one of the sockets to test the bulbs.
