Originally Posted By BradH
Drill bits or pin gauges, check every one you use with a micrometer to see what size it really is, not what it's supposed to be.
I also suspect that some import pieces are the closest metric size, rather than the correct inch size, based on some of the variations in measurements I've found.
This.
