I wish that a 1000 owner group of Cummins Ram owners
with dual batteries under the hood
would volunteer to do a long term test
with both a marine and automotive rated battery
Never put mismatched batteries in parallel. They won't have the same charge/discharge profile which will eventually damage both of them. Batteries in parallel should always be changed in matched sets even if only one is bad.
In theory, there is no difference between theory and practice. In practice, there is.
