drive shaft not bent I checked it with a dial indicator and it checked good .replaced slip yoke since it ad so much play in it and it helped tremendously . I also had a broken exhaust hanger and a bad right side tie rod had become very worn out where you could actually move the rod up and down about 3/16 of an inch .with all that being said after repairing and replacing all that the problem is gone.
