Did you follow the tuning guide for the set up? Can some one post the tuning guide?
You really need to follow the baseline set up - this is a proven technique - we have an official six pak tuner tester on here [sogtx] that tests all the info. Check your intake fitment - do the bolts line up properly? Probably not - you can use clay around the ports to check the gasket squeeze
