I've got OEM links and BLP & Holley adjustable links on various baseplates. There is NO functional difference once the adjustment is correct.
I adjusted the OEM links on two different baseplate setups recently... seriously, it's five minutes of your time (max), even if you have a couple of trial-and-error fittings. hammer
