The 1965 B body rear end is the best stock rear end housing to use on the 1962 to 1965 B bodies All the rest of the 1966 and later axle housing , including the 1965 station wagon rear ends, are wider
'65-'67 B-body, all body styles, same same. '62 and '63 are an inch narrower but have the taper axles.
