Might be hard to do on the ground (ramps? or if you have access to a lift) but you might have someone "wiggle" the wheel between the 11 and 1 you mentioned and see if the linkage is moving up and down. If not, I would tighten the box up some.
Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
