On alignment, in general, positive caster and negative toe (toe in) promote stability. More of both would be better if you can get it. 1/8" - 3/16" toe in and up to 5 degrees caster.
Still it should not wobble like that. Worth checking for something loose in the steering mechanism IMO.
