i recently replaced clutch in a 68 rr 11inch, when clutch was pushed in all the way, the 3 fingers touched on the springs of the disc. so i replaced the pressure plate with diaphram type pressure plate, now the t.o. brng. is touching the pressure plate. Free play is 1 inch or so? any ideas are all t.o. brngs. the same for 23 spline trans?
