Originally Posted By dickdale
Is it possible to use an a518 rh46 with a drive by wire engine harness from let's say Mopar or Holley?
Or do I need to use a cabble throttle body in order to make the kickdown work with an a518 rh46?
I make manual shift valve bodies for the 518 & 46re . No kick down linkage needed. No TCM Needed. Shift pattern is P R 1 2 3 4
