Pour something down the ports and see if they are leaking.
Agreed, with the head on its side with ex ports on top then with the intake ports on top pour some solvent in the ports & see if it gets wet at the valve heads. I read/saw something (on the dark web) so it has to be correct! that lapping is old school/obsolete & the article went on to say that the contact area will change drastically once it get hot so it is ineffective but I would think that yes heat is going to alter things but I'd want a perfect seal as I can get in the beginning for a good baseline. It does give a good pattern on the height/width of the contact area.
