34 or 35 is probably the correct number or very close to it for your combination. It isn't all that easy to figure out the "perfect" timing. It is a little easier on the dyno than it is at the track but you can sneak up on it at the track if you have enough time.
My new EFI system allows me to adjust the timing of each cylinder. That opens a whole new can of worms......
