Simple rule with water pumps - if the engine is running - the pump must be on - that way you avoid steam pockets or hot spots away from the sensor - Also you should be able to turn it on when not running to cool between rounds - many of the new engines with electric water pump and fan actually can run when the engine is off - this allows for a conrolled cooling cycle to avoid heat soak
