I'd wire it to a relay and have the ECU ground it to turn it on bad on temp, rpm, whatever you like, but then also have a manual override switch that will pull the relay to ground to run the pump with the engine off.
Or this:
Originally Posted By TRENDZ
Since you have the ability, I suggest you drive it with the ECU in pwm mode. This way, you can always have some flow without temp surge.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
