Usually, it's really not the coil that is any longer or shorter. It's the boot and wire. There are some boot kits available aftermarket (I know the Jeep 4.0 coil assembly has available boot kits). Wouldn't be impossible to make up some of your own. Just use the proper connection from the coil to the plug.
