I like "Turbo" mufflers for reduced restriction and reasonably quiet. They are pretty quiet at cruise and a little bellow with heavy throttle. For quiet with minimum restriction, use the largest size you can fit.
Dynomax makes a nice turbo. Also lots of others. Your local AP store likely has a good low cost option.
