Filling the bowl, replacing air filter, squirt the accelerator pedal the minimum amount to start the car and probably less than a second later crank and fire.
OK I'm still missing something here. You step on the pedal to set the choke, what happens? The pump squirts gas into the carb. Turn the key, Engine starts.
So...
Dump a small amount of gas down the throat, hit key, start the car. Maybe I should have said leave the door open to get at the key quicker?
I have mechanical Aptitude. I can screw up anything.
