Any idea what a shop charges for to replace a fuel pump?
Seriously ? $800 for a fuel pump. Then how come Rick auto has them for like $50.00 is that different?
If you don't hear the pump, and suspect that's the issue, have someone spray some starting fluid into the airbox while cranking, if it starts, then you'll need a pump, the pump avgs approx $400, and $400 to install....yes $800, DAMHIK
Gas today is so cruddy, that when you let a vehicle sit with a low level tank evaporating, which today's gas does faster, it builds up tons of deposits on the pump/sender unit inside and out, locking it up in place
