i'm in the process of converting to electric fuel pump and have 2 more questions:
- what do i do with the old stock mechnical pump? just unscrew it, pull it out and close the hole with a block off plate? or is there anything else to it?
- how do i properly hook the pump up? can i just go with a relay or do i need an additional circuit breaker? and (maybe the dumbest question: where is the best place to splice the pump into the ignition switch circuit?
i'd really appreciate your help!
