I am ordering my new pushrods monday and I have always put the #1 piston at TDC and used a adj pushrod checker and torqued shafts/rockers down to 25lbs and also set cam lash to get actual pushrod length needed...... is this the preferred method.. thx
solid roller setup
Mopar Performance
