You didn't mention anything about replacing the fuel filter. Those still have an external filter mounted on the frame rail I believe. Every time I burnt up a pump on my high mileage Dakota it was because the fuel filter was clogged up.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
