Originally Posted By MR_P_BODY
sounds like you have a flow issue still.. either
the radiator is too small or is plugging up..
a good radiator will run fine on the street at
50mph without a fan(has enough air flow)
wave
I agree
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm
Power by Tex's Automotive
