Take the washer out. you do not want less flow, you want more. Putting a washer in the coolant flow is like putting a piece of cardboard in front of the radiator with a 6" hole cut in it.
But a thermostat reduces the flow as well
A thermostat is not designed to make it run cooler, it is designed to make it run hotter than it would without one.
