if you can't maintain temperature & it is exceeding your thermostat rating - the excellent flow & open thermostat may not allow the fluid to spend enough time in the radiator to cool
so then, why when a car is running hot, do you " race" the engine, thereby speeding up flow? wouldn't you want it to idle, so the coolant spends more time in the radiator?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
