Bat wings are my solution to that issue. I've been selling quite a few of them since they came out and they seem to be working. I've used them on several engines myself over the last year and they work great as long as you are careful with the RTV. Too much is bad, too little is bad. You have to lay down just enough RTV to seal the wing to the center section without squeezing a bunch of excess down into the engine.
