Tunnel is completely in with Dynaliner. Trans is in with oil. Drive shaft is ordered. Gotta wire in neutral and reverse switches, bleed matster cylinder, install steering column and carpet and done.
Any adhesive backing or rubber membrane with that "Dynaliner"? if so it's going to melt/stink with the heat from running in prolonged OD...DAMHIK
FYI: did you slide any high heat spark plug sleeve covering over the braided lines on the hyd TOB set up? to avoid a spongy pedal when the fluid gets heated up from underhood/exhaust/headers/etc heat sources?
Mike
