Originally Posted By HotRodDave
a soft plug will not work, the oil will squirt out the bypass hole and flood the rocker area, may even drain the pan as well as a drop in oil pressure.
+10000000000000000000000000000000000000
it will not work it bleeds off pressure , I pulled a wrecked Molnar crank and some burned up Oliver rods from a short block that someone (not me) tried it on.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
