New springs on my '74 Charger have the rear end sitting a bit too high for my liking, and would like to add lowering blocks. Maybe 2 inches...
Due to the revised rear spring for '73-'74 with insulators, I'm not sure how to proceed. I did some research and all I came up with is something about using a bushing for the spring pin, and using a '71-'72 style spring plate to eliminate the insulator set up.
Is this really doable, and can anyone break this down as to how to do this and what parts I would need to acquire?
Thanks!
