Some folks drill out the plastic pins that hold the steering shaft together and extend the shaft to make the power steering shaft longer. The pins exist for safety reasons so this is not the answer. You might look around for a used manual steering shaft - sometimes they are cheap or someone may want to go power steering and swap you.
