Originally Posted By 62SAVOY
It seems not to long ago there was a topic on this. I have used the search but can not seem to find it. People were telling about what they ran. I have a 440 blown engine and run solid lifters usually with additive. Just wondering what is good to use. Uncle needs to know for his car also he just got.
Todd
You didn't say whether either engine has a flat-tappet cam and that's very important. This thread like others before it has lots of people stating their favorite oil without saying they're using a roller cam. Unless someone states that the oil they recommend was used with a flat tappet cam assume it wasn't.
Be very careful with the Valvoline oils. You'll find lots of posts saying they use "VR-1" but Valvoline puts VR-1 on the label of just about everything they make. I'm pretty sure the marketing wanks at valvoline wear VR-1 underwear at all times. If you want to run your flat tappet cam with Valvoline oil be sure to get the RACING version.
twocents
