Not sure on all polys but '59 318 the head has cast pedestals that are machined so the shaft can fit in and I believe it is pinned at the ends. There are no caps on that motor to remove. As space is tight, if the shafts did need to be removed, there not coming out while in the car.
68 AMX mopars red headed stepchild
69 Dart GT Convertible 340 4 speed
71 Challenger - looks like the avatar!
